I removed the 230, 6 cyl. and plan on installing a 355 V8 with a 700r4 auto transmission. My question is,,,,what transmission crossmember do I use? Also does the crossmember that the 3 spd trans bolted to, does it get cit out? And last there's a third crossmember that the ebrake is attached to,,,,,does it work staying where it is?
The transmission (ears ) that the bell housing mounts to needs to be removed, the rearward crossmember that the E-brake is bolted to can be used as is but you`ll need to move it back for the trans to bolt up too...you may or may not have to move the E-brake hardware to the side.
