I am building a 66 C10 (long bed) and was wondering what sort of top speed I can expect?
I have a slightly modified 350, 700R4 transmission and standard 12 bolt rear diff.
It depends on how your rear end is geared and how tall your rear tires are. Many truck,s had 410 rear gears andabout 90 was top end. My old 283 with 410,s would wind 30 in low 60 in second and 90 in high. Installed a 390 Horse 427 and 10-15 rear tires and it would hide the speedometer in a quarter mile. Boy I miss the days of 30 cent per gallon high test gas!
29 inch tires with a 700r4 with a .69 final ratio
engine Speed (RPM) MPH 3.73 Gear
8000 RPM 268.17 MPH 243.97 MPH MPH
7500 RPM 251.41 MPH 228.72 MPH MPH
7000 RPM 234.65 MPH 213.48 MPH MPH
6500 RPM 217.89 MPH 198.23 MPH MPH
6000 RPM 201.13 MPH 182.98 MPH MPH
5500 RPM 184.37 MPH 167.73 MPH MPH
5000 RPM 167.61 MPH 152.48 MPH MPH
4500 RPM 150.85 MPH 137.23 MPH MPH
4000 RPM 134.09 MPH 121.99 MPH MPH
3500 RPM 117.33 MPH 106.74 MPH MPH
3000 RPM 100.57 MPH 91.49 MPH MPH
2500 RPM 83.80 MPH 76.24 MPH MPH
2000 RPM 67.04 MPH 60.99 MPH MPH
1500 RPM 50.28 MPH 45.74 MPH MPH
1000 RPM 33.52 MPH 30.50 MPH MPH
A th-700r4 is an overdrive trans, ( four speed) The gearing that was used was 3.06 for first gear, 1.63 for second, 1 for third gear, and 0.7 for fourth gear, essentially a 30% overdrive. those speeds posted are for a built motor.
