1 - 11 of 11 Posts
I have a1976 Chevy truck 350 5.7 , the truck runs and drives good but for some reason it just shuts down when I am coming to a stop . It idles perfectly , I just can’t figure out why it just turns off , has anyone had this issue or have a clue of what it could be
yes , it was running fine for a while when I would take it out but know it runs good,the idle is where it’s supposed to be but it just automatically shuts off when I come to a complete stop or on reverse
If only when braking , brake booster if fitted ? If so temp unhook and plug , then try that .
automatic transmssion ? if so, will it not stall if you put it in neutral ?
Could be fuel starving too..
Certainly sounds like a carb tuning issue, first I would increase the idle speed and see if that helps.
1 - 11 of 11 Posts
