howdy! i'm gettin ready to swap my Saginaw 3 speed for a NV 3500 5 speed! my question is; will i have to cut my hump/floor board out for clearance? Also, what other issues will i run into, other than electronic/mechanical speedo, hydraulic clutch, shorten drive shaft, 32 spline yoke, different crossmember, proper pilot bushing, cut a hole for the shifter, b/u lights, i think that's all.....? Thank you in advance for your help!!!
Discussion Starter · #2 ·
Well, i'll answer my own questions..... I did have to cut the floor board! It made installation much easier! drive shaft length is perfect! Clutch conversion works great! Truck is very fun to drive now! i can go down the interstate @ 70 miles an hour @ 17-1800rpm's.......
