I put it in drive does not want to pull. rivs up. as it idles back down it acts like it want's to pull. truck has set up for a year and 1/2. has a 350 trans. in it. It will move the truck around. pulled it into my garage. The guy I bought it from just replaced the front seal, said that was the reason it was parked, had a bad leak. acts like it low of fluid. Thanks Joe
Did you check fluid level?? If he changed the front seal he could have drained the converter. You may need to add as much as 4 to 6 quarts. Check while in neutral level and ideling. let it warm up. anim_25
