Hey Guys, planning on changing my 350 trans to a 700r4, looking at the trans mounts at bowtie overdrive. They have two different ones, not sure on the one I need. I have a 65 stepside. Thanks Joe
I would think your local parts store would have what you need. Things under there have been changed since 65 so you'll have to do some research.
Are you talking about the mount or the entire crossmember, if it`s the crossmember, you can use one from any `73 to `87 C10 auto will work or use the one from Bowtie overdrive, the 7004r will move the crossmember back about 6 to 8 inches, the difference in the crossmember is where the E`brake cable mounts to the crossmember on the factory set up, look at the details.
http://www.bowtieoverdrives.com/catalog/catalog_inc/viewitem.php?ITEMID=108
http://www.bowtieoverdrives.com/catalog/catalog_inc/viewitem.php?ITEMID=106
