Discussion Starter #1
I have a 1972 Chevy C10 SWB that came with leaf springs that I am trying to convert to trailing arms ride tech kit
I also bought these Rear Trailing Arm Axle Seats.
I have everything bolted on in a way that it can be moved around and it all fits together.
I have two problems:
1. What angle do I set the rear axel to when I weld the seats on?
2. Exactly how far in do I put each axle seat?
Because the geometry has changed so drastically with the new suspension, the driveshaft is now too long and does not fit. So I can't connect the drive shaft from the trans to the rear end to get the correct angle or to center it.
¯\_(ツ)_/¯
Pictures:
https://imgur.com/a/YKv0OLQ
you have a number of things you need to work on
Regarding Rear Trailing Arm Axle Seats angle you need to check out the following info:
https://www.drivelinesnw.com/part-t...ysis/measuring-and-correcting-angle-problems/
This is one of many sites regarding driveline angle.
You are going to need a new drive shaft.
I have a 72 short bed and I replaced the center cross-member with:
https://www.performanceonline.com/1...h-Anti-Squat-Brackets-Coil-Spring-Suspension/
That way you can install a one piece driveshaft.
Hope this helps somewhat and if I have sometime this weekend I'll measure the location of the axel seats.
