is it possible to retro fit the 73-87 sway bars to a 72? front suspensions seem very similar. and i know you can bolt up a whole 73 front suspension but my 72 suspension just got rebuilt and id like to put a sway bar on without breaking the bank with aftermarket...
thank you in advance
Yes sir...! go to your local auto wreckers, any 1.25 ( the largest ) sway bar will work from any C20 or 1 ton chevy truck or suburban, get all brackets with sway bar, replace all rubber with new, and bolt on...done. ( you may have to drill holes but most already have the holes in the frame for them).. beer
you say C20 or 1-ton... i have seen 73 and later 1/2 tons with sway bars....will those not fit? or is it just that they are a smaller diameter?
They will fit fine, just about half the size...the larger ones improve it a lot better..
