1 - 9 of 9 Posts
John I had done a search, everybody is using the same copy from the book, and I have the same book, and its just as blury.....!sign0013
Well that's sucks! Maybe I need to knock back 3 or 4 shots of Makers Mark and see if it gets clearer? :D beer :D
Trim holes appear to be as follows?:
  • Front Fender: 6 @ 21/64 = .328"
  • Cab: Upper Holes: 6 @ .338"/.353" & 4 @ 5/16", Lower 5 @ 1/4"
  • Bed: Upper Holes 24 @ .338"/.363", Lower 11 @ 1/4"
Thanks for the input Rich.
John give me til later on today, I`ve got a junk door out side that some one gave me, that had the trim on it , I`ll measure the holes, count and spacing.
Let me know if it makes sense...or I need to translate..my mess anim_63
Sorry the hole sizes were in mm, my calipher kept changing ( digital) MM/standard, if you lay it out on tape and something don`t look right holler, I`ll double check it....
Discussion Starter · #8 · (Edited)
Sorry the hole sizes were in mm....
6.10 mm = .240 inches
8.58 mm = .338 inches
Well Rich, looks like the holes you measured match the drawing. Thanks for your help, looks like I now have the data I need.
Roofus, from over on "The Stove Bolt" turned me on to these that are a bit clearer:
I`ll save yours and mine, been considering putting mine on if and when I buy...anim_63
1 - 9 of 9 Posts
