Got rust starting to show in my headlight refectors and want to change them out. How difficult is this job and will any sealed 7" reflector/lens/bulb work? Should I do a H4 conversion?
Thanks, Joe
Any sealed beam will fit, if you upgrade to halogens you`ll need to upgrade the harness in the front, the stock head light switch will fail if you don`t heres a couple of harness diagrams with relays to remedy the issue, note even with the stock sealed beams this harness upgrade will make a marked improvement in lighting..
Great thanks! Since this truck will only be driven during the summers here in Sweden and with sunset around 10pm, will I then stick to the stock sealed beams and avoid the trouble of doing the wiring.
