hi guys!! just recently joined the group...so I hope I don't get banned right off the bat for asking this question. I'm considering installing a ford 9" rearend in my 69 c10. was wondering if anyone else on here has done so and would be so kind as to share any info and parts list you may have kept track of for this installation. thank you for your help!!!
No Love For The 12 Bolt?
sign0016 to the forum. Got any photos of your truck you could share with us here?
I've done 9" Ford swaps before, but not on a C10. I do have a '65 C10 though so I am familiar with the 1963-1972 trailing arm suspension.
You'll need to:
I am curious, why not use the stock 12 bolt truck axle? They are very stout and companies like Richmond Gear have about any gear set a fella could ever want?
sign0016 1450 I have done that to my 71 C10 but it had leaf springs in it already No big deal. I redrilled the axles to match chevy bolt patteren
Are you currently runing trailing arms and coils or leaf springs....? If memory serves me right your rear axle is 61 inches wide, they changed in 70 and rear axle width went to 62.5 wide, that is as far in width you would want to go, although the you have larger wheel openings you could possibly get by a half inch wider, measure at the wheel mounting surfaces with the brake drums on...! Don' confuse the ford eight inch with the nine inch, quick tip you cannot get a socket on the bottom two Carrier bolts on a ford nine inch....!
Is there a specific reason for changing to a ford nine inch.....?
Another side note...Lincoln /Mercury rear axles use a 9 3/8 ring gear, no parts will interchange with a ford nine inch except maybe axles but only the large bearing, they are strong but limited gear ratios....!
1965-1966 Mustang 57.25 inches
1967-1970 Mustang 59.25 inches
1971-1973 Mustang 61.25 inches
1977-1981 Versailles 58.50 inches
1967-1973 Mustang, Torino, Ranchero, Fairlane 59.25 inches to
61.25 inches
1957-1959 Ranchero and station wagon 57.25 inches
1966-1977 Bronco 58 inches
1977-1981 Granada/Versailles 58 inches
1967-1971 Comet, Cougar, Mustang, Fairlane 59.25 inches
1964 Falcon 58 inches
1967 Cougar 60 inches
1967 Fairlane 63.50 inches coil springs
1972 Ford Van 3/4 ton 68 inches
1973-1986 Ford Van 3/4 ton 65.25 inches
57.25 inches
narrowest 9" housing
1966-1977 Bronco 58 inches 5-on-5 1/2 inch diameter bolt circle
1967-1973 Torinos, Rancheros, Fairlanes 59.25 inches or
61.25 inches
1967-1971 Comets, Cougars, Fairlanes 59.25 inches
