Rear leaf springs can weaken , flatten , sag or any one of the leaves can fracture or break. Need to have a good check especially if used to carry heavy loads as is very common with farm trucks
My truck actually has coil springs. Probably same result over time. ThanksRear leaf springs can weaken , flatten , sag or any one of the leaves can fracture or break. Need to have a good check especially if used to carry heavy loads as is very common with farm trucks
Apologies , I wrongly assumed it may have had rear leaf springs which apparently was an option on that year / modelMy truck actually has coil springs. Probably same result over time. Thanks
I have a 69 long bed with coil springs as well.I have a 69 C-10 long bed. It was used on a farm for years. The rear is really bouncy. I haven't changed the shocks yet. Shouldn't the rear springs have more tension? Can springs simply wear out over time? What have you guys seen? Thanks
