Will a 73 blazer 4x4 rear leaf spring fit my 72 blazer 4x4 rear spring perches? they are the same length. just wandering if the 73 spring pad bolt tabs will line up to my axle perches. Thanks
Hi,
Did you find your answer? If so, will it work. If you haven't figured it out yet, It should work. You already have the total length. Get the distance between the rear of the 73's and measure that up to the other ones. If that's the same your good to go. How about how many leaf springs?
