Hey guys! I have a 383 stroker and I tried to do some research as to which grade of oil to put in, a lot of people said to go with the 10W40 which is what I went with, I don't plan on driving the truck a lot and do plan on changing the oil reguarly, any suggestions? Also what is the standard qts of oil it takes?
A stock pan will require 5 qts with filter Best way to do it is put in 5 start it for a few min. and check again You could have a different pan. it which case add oil till the stick says full.
