· Registered
I recently bought a 69 C10 stepside. The wheels on it are 18x8 with 265/65/r18. If it matters, they are also 6 lug. I’m looking to lower the truck some and I was thinking of putting a set of 20” wheels with a set of low profile tires on. What wheel size will fit this truck front and back and what is the offset? I’m having a hard time finding this info on wheel manufacturers websites. Thanks for your help!
· Registered
you're going to have to come up with the mounted diameter of the wheel and tire and check the offset of the wheel. try to match the front and rear offsets if you can so you
can rotate all four wheels. if you're stuck on the rims get them first then lower to a workable height.
· Registered
I can't help on the stepside. However on a fleetside I have 275/45/20 on the rear. Zero offset on the wheels. My truck is lowered 5".
You simply can not go much wider or lower without hitting.
Currently I never hit the tire. Good luck.
· Registered
LOL I can't help you with them "Wagon Wheels" but here is the Math for a 15x6 6 lug Wheel.
Handwriting Rectangle Font Parallel Slope
