so after having my truck sitting for about 5 months finally got around to getting it to start back up and even took it for a ride but now only about 30min later it won't even try to turn over. it's not even trying to turn over, can't even hear the starter try to turn over. it has a new battery that I put in this weekend. :confused:
Welcome to the forum first off sign0016, so new battery, things to check all wiring connections, tight and clean, ( had one that looked good, battery kept going dead, turned out the ground cable was loose on the inside of the battery clamp, pulled out when I tugged on the end hard..) grounds if you don't have them put some on now, engine to frame, frame to cab, cab back to engine, check firewall plug next to heater box, your solenoid wire come thru there ( purple wire) if the contacts are corroded clean them and use dielectric grease on the contacts....on then start checking alt if battery is dead to see if the alt is good...
