Hello c10ers I am in the process of prepping frame for paint and found a broken rivet that holds control arm in place any ideas where to locate one.
A picture of te broken part would help.....You may replace the rivet with a grade 8 bolt of the same size.. though you may have to drill it out to get a bolt to fit.
As Charlie said, grade eight hardware, bolt/nut and a lock washer or self locking nut, you may want to check the rest of them, if loose replace as well...
