1 - 11 of 11 Posts
76 Chevy 350 was running fine died out like you
Just turned of power
Set a while started run and drove 10 minutes
Done it again
Finally would not start at all
No spark getting fuel
Replaced coil ignition mogule and condenser
Checked ring with teeth in bottom of
Distributer can’t think of name
Of it right now with meter shows to be
Ok not grounded out still no spark
Checked roter no burn through cap goodcheck
Wiring what am I missing distributer is
Turning ok so is it possiable that it’s bad
And I’m not reading it right with meter
Maybe grounding out
Why would it run then lose spark lot of
Questions just trying to figure this out
Thanks in advance guys for the help
I`m a little confused as well when he said condenser...Is this a HEI or points style distributor..?
Some times the HEL coil on the top has a broken ground or lead wire in the cap and is not readily seen, when you do a continuity check on the cap with the coil removed will it become apparent, offshore cheap caps have poor lead wired built into the caps..for further testing
http://chevythunder.com/hei_troubleshooting_page_2_coil_.htm
The (condenser) is that of sorts, it suppresses radio electrical noise, static, if your old enough you`ll remember them being hooked to the early coils, actually I haven't seen one on a HEI before. Your HEI have you checked the center electrode that is on the underside of the cap where it touches the rotor, its spring loaded, ensure that it is not stuck up inside of the cap. just lightly press on it so that it springs back out.
1 - 11 of 11 Posts
