Just thought I would pass this along, although this was done on a ford F100 the applications are limitless... Jag XJ6, front suspension, track width is 59.5 inches, its rated for 5800 lbs, you get four piston calipher disc brake, coils, forged a-arms, rack and pinion, and it has 5x4.75 bolt pattern...you just need to build your own mounts, the ford pictured has a 34 inch wide frame...
