What is required to install a set of front and rear sway bars onto a 72 c10 that doesn't currently have them, any cutting drilling etc. Will the stock lower a arms work?
Most C10`s already have the holes for the sway bar, what you really want is a sway bar from a 3/4 or 1 ton, they are minimum 1.25 in diameter, get it from a donor truck and the brackets, then replace the rubber and bolts from your local auto parts store and bolt them in. Makes one huge difference in handling....
