Premium Member
When it is rains, when the humidity is very high, my car in the garage often gets moisture all over it due to the high humidity.
I solved this problem by simply putting a box fan in the garage and leaving it turned on, no more moisture buildup on the car, engine etc, causing rust.
Otis :)
Otis we have the same issue here in the spring if we get a lot of rain with little wind, I've done the same...
So are you leaving the garage doors open or ?
I too had this problem when I lived in Ohio. I used a "Car Jacket" bag on my cars in the late Fall / Winter with used cans and bags of desicant inside and under the car, inside the bag.
My solution was moving to the arid high plains of Colorado. Problem solved.
anim_25
depending on you garage, you could install some kind of vent or vent fan pointing towards the outside ...
or this isn't an option ... ?
