Hello, all. I'm new to this forum, but I need some help figuring out why my horn won't blow. We got it working for a while, although it sounded weak, but now it won't blow at all. Not sure whether to spend my time on the mechanism itself, fuse, or relay. Thoughts?
Thanks
John
Replace the horn relay, insure all the ground points are clean, on the rag joint ( depending on what year truck you have, you did not say) there is a continuing brass ground strap from the upper part of the column to the lower, check to see if its even there or broken..
