Guys, I have looked high and low for an assembly diagram for a '57 steering wheel/horn button. I disassembled my steering wheel/horn/turn signal assembly some time ago and did not take photos or notes (thinking I would immediately reassemble it)...duh, a year later I am trying to figure out the reassembly order of the horn parts and where I attach the previously missing horn wire (which is why I disassembled it in the first place). Any thoughts...should I sell this truck and buy one already assembled?
Sheet Metal Junkie
Most horns will ground out in the column completing the circuit. The power will come out of a relay or directly from a powere source into one side of the horn and out the other side up into the column to the connector tab which when depressed will ground out and activate the horn. I may still have wire diagrams for basic wiring.
Schematic from 63 corvette, but should give you a clue. Hope it helps.
Second pic
Couldn't get both pics to load on same page for some reason
