Hello. My name is David and I have just purchased a 1965 C10 short bed fleet side that i will import into NZ at the end of the month. It needs a little work so will be searching this forum and asking a lot of questions so I can get it done and done right :)
Welcome to the forum David, glad to have you here,,sign0016
Thanks 406Rich. Can you or Charlie point me in the right direction/to the right person who will be able to advise on power glide to 350 auto change?
Piece of cake David....powerglide and the short shaft th350 same length, same spline count, just swap them out. You`ll need to connect the kick down cable with the appropriate brackets, by a new flex plate... note the TH350 came with 3 different tailshafts, 6, 9, and 12 inch tailshafts, you`ll need the six inch tailshaft...I`m assuming this is behind a V8....?
