1 - 8 of 8 Posts
Connected the heater and saw why it was disconnected. Water everywhere. So I tried to source a new core but not easy and quite expensive I thought. So I'm going to give it a go myself. Its all dismantled now and on the bench. I am going to coil some 10mm (3/8"for the uninitiated) soft copper tubing together with the necessary fittings in place of the old core. Its a cheap fix but hopefully will do the job. We shall see.
You live somewhere that you don't need heat or defrosters??
Not quite. The truck has just been imported from California to the UK (London area) hence the disconnected heater. A new heater element is £300 ($450). That's why I'm going to have a go.
450 don't you guys have salvage yards there.. GM heater cores are all similar easier to make one fit than make a new one, but good luck either way
All done
I removed the old core and replaced it with a coil of 10mm (3/8") soft copper micro bore tubing. Well it works ok, Not perfect but it works and at £8 ($12) total cost is good enough for me. As its only a small cab it should be ok.
Automotive tire Motor vehicle Rim Machine Engineering
Gear Gas Auto part Machine Automotive wheel system
Crankset Automotive tire Motor vehicle Rim Bumper
Automotive tire Motor vehicle Rim Gas Automotive exterior
1 - 8 of 8 Posts
