1 - 20 of 21 Posts
I have been trying to fix my one barrel carb on the truck for several days. Started leaking fuel thru the vent on top. Had a rebuild kit so I used it and still have the problem. Tried two different floats and adjustments. Sure wish I could find a two barrel manifold for my V6 so that I could buy a two barrel carb and put on since they are more readily available. Anyone have any suggestions or an intake manifold for sale?
Don
I have the 305 and yes it does have new needle and seat. I even had an extra carb to swap thing out with.
I like that Trans-Dapt you linked me up with. I might even have a two barrel carb sitting around to try with it.
Thanks loads!
Don
Don, do you have the stock fuel pump on this...?
I did install a new fuel pump but it is the stock replacement Rich.
Turns out Amazon had that adapter so it will be delivered tomorrow. :)
I do have a 2 barrel Stromberg WW carb that I plan to try on it.
Don
Don
Just wondering if you need a fuel pressure regulator and limit the pressure to 3 lbs.
I will try that if the 2 barrel has the same problem Rich. Thing is it did not start doing this until two weeks ago. That said, I did add 8 gallons of gas to the tank.
I think I have and adjustable regulator that came with an electric fuel pump that was on my 57' 3100 if needed.
Don
Discussion Starter · #11 ·
Got another Stromberg 2 barrel carb from a friend and installed it. Works fine and does not leak but now I have to come up with some way to connect the linkage. Believe the carb came of a Trifive.
Don
Discussion Starter · #12 ·
Well the adapter and 2 barrel carb is on. I had to do some work to get the linkage correct but that's done now. Took it up and down the street and it runs pretty good. I was even able to verify it goes into all three gears. :)
Don
Discussion Starter · #16 ·
Well I finally think I have my carburetor problem resolved. I have now installed the 2 barrel intake manifold that I got from another member with a new Holley 500 cfm carb. Cleaned up and painted the engine area. The good news is that it fired up right away and purred like a kitten at idle. Bad news is when I drove it down the street my electrical power died intermittently and so did the engine. Seems like a ground problem but don't know what for sure. Will be looking at it more today and tomorrow. Here are some pics.
Don
Intermittent electrical problems can be a big pain. since you were in the rear of the engine it may just be a loose ignition wire anim_25
Discussion Starter · #18 ·
So I do have it running again. Seems to be something in the wire harness going down from the positive side of the coil heading downward. I moved it around until I had power to the vehicle again and then was able to start it. I will have to try to unwrap that harness now. :(
Here is a short video. https://www.youtube.com/watch?v=i2AGPHcnjY0
I`m only guessing that is the firewall plug next to the heater box, it contains the solenoid wire, and temp gauge wires and the wire back to the coil....
Discussion Starter · #20 ·
You are correct Rich! I must have dislodged it a little when I was working on it. Didn't get an update on here yet.
Don
1 - 20 of 21 Posts
