I have yet to see a "rear fill" rear frame mounted fuel tank that doesn't hang down like a ruptured duck. If ya think about it, the license plate is low, and if the filler neck is there the entire tank will need to hang below that point for it to fill correctly.wondering what tank guys are using for rear fill. That will fit between frame rails. Fill behind license plate. Someone told me a chevelle but none I've found will fit.
Thanks Charlie
..... some installations look good, some hang down pretty low.Well after more though I think I'll put the tank under the bed in the rear and put in a side fill. Maybe an early suburban or blazer tank?
What sending unit would be used for this?For those looking to purchase a tank like this one it is from a 87/91 Suburban or Blazer. E=Bay about $100.
Hope this helps
That tank sender is a twist lock design, I believe they only come in 90 ohm, will not work with 60 to 66 C10`s only `67 on up ohm wise, you really did not say what the install was on..What sending unit would be used for this?
If your buying the tank thru Tanks Inc they sell a VDO 30 ohm sender for that tank. But be sure to confirm that with them before purchase.I was leaning towards using the '49-'52 year car tank in the rear. Would the sender for that year work on my '61?
