Anyone using an under bed fuel tank use a junkyard Chevy fuel pump? Which one (car/truck model) did you get & how did you modify the tank?
Engine is a 2002 5.3 LS with a new under bed tank just right for modification.
Interesting.....and
Tanks,inc also has an assortment of retrofit items. However with thousands (millions) of stock GM tanks/pumps in the salvage yards, I was wondering if anyone had adapted a GM unit to their steel tank. One of the LS swappers guides books mentioned this possibility in passing, but did not elaborate. Surely would be easier for my Grandson to hunt a GM house if something goes south on him later on.
But thanks for the food for thought. Excellent video!
Tanks inc.....
Has a bowl type pump top that welds/bolts into the tank upper flat surface. If you add some plain round bar stock welded at the appropriate positions, you should be able to run a stock Chevy pump.
hi runem i used a pump out of a 01 6.0 ,used a steel tank from ebay cut a 3 5/8 ths hole saw shortend the fuel pump about 3 inches flared the ends after installing plastic inside fule bowl installed the 3 springs got a fuel tank ring from vett works weleded in to tank came with all info .installed fuel pump in tank ran lines with a kit from s.u.r & r. complet kit to do from pump to fuel lines on the ls engines a snap.installed in about an hour ,taken my time on my 66 c10 swb bbw ls1 5.3 4el60 hope this helps .
