My mechanic and I are having some problems with switching to the Sniper EFI. We have to change the 3 port fuel selector valve to a 6 port fuel selector valve. As you may know the 6 port 1 wire selector valves are hard to find. We want to minimize electrical changes so are trying to find a way to utilize the 6 wire valve without rewiring everything. I found a post (link below) where a guy used a double pole relay to bridge that gap. Only used the current one wire and added a constant. Do you feel this is a viable approach? Have any of you tried to accomplish something similar? If so do you have any details on the relay to use and the wiring diagram for it? Any other ideas or suggestions? Any information is greatly appreciated.
Or, does anyone have a lead on a new or used ACDelco 467513 fuel selector valve? Other than the one on ebay for way too much $.
http://www.barthmobile.com/eve/foru...31087061&m=4303955787&r=6213934197#6213934197
I did read a few posts from the past on my search, seems everyone has gone to relays as the switch and the replacement switch are no longer made.
