Just disconnect the wire from the tank. First look at the gauge, disconnect the wire and see if there is a differance. It should go to empty. Then ground the wire and it should go to full. If all this happens your sending unit is bad. If nothing happens chances are you gauge is bad OR a bad wire .. Good Luck
