1 - 9 of 9 Posts
I have a set (4) 66 & older wheels/rims. These are the early design with 3 nubs for the smaller hub caps and are correct for these years stated above. Inside dia. of hub caps will be 10" for usage. These wheels are 15", 6 lug, 5.5" wide, 3.75" back space, center hole is 3.5" dia. ****As you can see from the pic's they have been glass bead blasted and Epoxy Primer painted and heat baked.**** I have had them tested at a local Tire Store and they are acceptable from the Tire Shops Manager and I also watched them being tested also. Any more questions PM me. thanks for looking
15" steel wheels
Will you ship to fargo, ND?
Mr. caraholic78 it is Customary to respond back in a timely manor when asking for an answer to your Question from a Seller as you just might be holding up other perspective buyers not necessarily from this forums classified section. Thank You for your respect if you have any!
Discussion Starter · #6 · (Edited)
15" Stock Steel Wheels/Rims
It is a shame that some people (new) here to forums need a lesson in the usage in being Etiquette, but I guess it is true you *Can't* teach old dogs anything. He lost his Opportunity in a purchase. (first set sold)
***UP DATE ***, I ran across another set (4) stock wheels for 66 and earlier Trucks with the same spec's as above in my original posting, 15" by 5.5" wide, 6 lug, 3.75" back space, 3 nub for stock hubcaps. Same price applies, cleaned and sand blasted with epoxy primer paint and Heat baked for hardness. $250 a set, shipping if needed is extra. Please if enquiring respond quickly, even if you don't want these wheels after getting a shipping quote it wont offend me if you say no to the deal. Thanks for looking.
I have a set (4) 66 & older wheels/rims. These are the early design with 3 nubs for the smaller hub caps and are correct for these years stated above. Inside dia. of hub caps will be 10" for usage. These wheels are 15", 6 lug, 5.5" wide, 3.75" back space, center hole is 3.5" dia. As you can see from the pic's they have been Epoxy primed and heat baked. I have had them tested at a local Tire Store and they are acceptable from the Tire Shops Manager and I also watched them being tested also. Any more questions PM me. thanks for looking
******** UP DATE (6/12/2017). The above set is Sold. I have one more set for sale with same spec's but these were sand blasted and Epoxy Primer/Sealer Painted. Also offered at $250 + shipping if needed.
UPDATE as of 8/6/2017
The original set was sold @ $250. My update for the same specks in the 2nd set of wheels (6/12/2017)
update as of 8/6/2017
the original set was sold @ $250. My update for the same specks in the 2nd set of wheels (6/12/2017)
***up date*** both sets are ***sold***sold***
1 - 9 of 9 Posts
