Hey guys I've searched just about everywhere possible for the front drum assembly for my 64. Need the drum and rotor/hub can anyone point me in the right direction or offer one I can't afford a full conversion yet and drive the truck almost daily
You can get the front drum and hub thru LMC, they are separate, you need to grind the rivet heads off the outside of the drum, his will separate the two if you only need the drum, they were riveted at the factory to save a step in the assembly of the trucks on the line and for no other reason, so if yours is still riveted its the original and never been turned brake drum....pictures worth a thousand words http://www.pbase.com/nufsed/drumbrake
Lmc
I have looked in ever lmc I own there is a faded picture of it but no order details. It is the front right hub
Ok,
Try here, http://vintagechevytrucks.com/
You will have to go to the contacts and call him. They are re-doing his web site and it is not up completely.
He is more of a wrecking yard type but can probably get you good
OEM parts, used but good.
He is here on the west coast so who knows what shipping would run.
Or maybe there is a place like this closer to you.
You might try calling Wes at Classic Heartbeat. He might still have what you need but not on his web site.
This may be one of those wrecking yard only items, `63 to `66 are all the same....except c20...
Hey terry talked to the guy at vintagechevytrucks.com he had me hooked up with the right part in a few minutes. He sends his thanks for the refferal should get the drum Saturday I'll let y'all know how it works
