My 1972 C10 does not have the original engine. The one that is in there is stamped with F0323YW. I have not been able to ID this. The casting # is 3858174. Thanks for any help.
suffix code YW denotes it as `68, 220 hp, 327 C.I. You need to look at the head casting number as well
http://www.nastyz28.com/gm-chevy-codes/chevy-engine-codes-suffix-10.php
Matt the suffix code last two digits thru me off...The (YW) are you sure its YW and not YV or YU. So I`ve changed the engine profile...
the suffix is not listed but by the casting # it is a 64/67 327 300HP. did you pull the valve covers to get casting numbers there
I have a partial listing from the Hollander exchange manual, YW is not there as well...
The numbers on the block and crank confirm it is a 64-67 327. The heads are later model so they are no help. I was just curious as to what it came in originally, but that is not real important. Thanks.
