Came across a pretty good deal on a parted out engine.
Flat top pistons
292 Cam
400 heads
350 stock the rest of the way down.
I have an edelbrock performer intake, Long-tube headers and 600 edelbrock to put on top of it.
Is there anything I should do besides the usual on machining? I plan on beefing up the springs but don't know what size/type I should get ( any help would be great ).
Thanks in Advance
Dizzy
Use Remflex gaskets on your headers and collectors. And ARP bolts. Don't cheap out on the hardware and gaskets. The cam you are running is going to determine the spring combination. Check with them.
