Will an electric fuel pump mounted in front of a dual tank selector valve, push fuel through a mechanical mounted Holley fuel pump, on a 350 chev motor?...A friend said he did this on his Mopar, without having to remove his Carter mechanical pump....problem I have is that if the truck sits for a few days. .it takes a while to get fuel back up to the carb, and I have some expensive fuel lines hooked up, that I would rather not have to replace if possible.
