I just bought a 86 c10 with duel tanks, Do they need to be filled separately or can they be filled from side only? Also must they be switched or do they feed as one? I have had a couple vans in the past with duel tanks and both were connected, filled on one side and drained as one. Thanks for your answer.
77 Chevy C10
I think they are totally separate. Not 100% sure. But its easy enough to tell. Look underneath the vehicle. If they are not connected it will be obvious enough.
Should be separate and there should be a switch on the dash. But yes, look underneath. You want to keep a little gas in the unused tank. I'm eliminating both my tanks for a underbed tank. I have passenger side tank disabled. I'm thinking if I switch to the disconnected tank, this may be a good theft deterrent for now?
Ok, Thanks for the help,,
