Well I thought I had everything working lol. The dome light wiring has been cut and Can any one tell me where the black and white wire goes coming from the lamp? There is no wires coming from the tank nor going to tank. Im not electrical guru so simpleton terms would be appreciated. Thanks David
Well I sure your dome light has a ORANGE wire going to it that originates at the headlight switch. I don't recall the gas tank wire colors but you should be able to look at the back of the gauge and tell .anim_25
David there should be two wires dropping down from your fuse block orange / white, these would be you dome ;right wires, the gas tank has two one is a ground and one is brown goes from the sender to the fuse block marked gas/gauge
