· Registered
1965 Chevy C10 Longbed Fleetside
I need to replace the Rochester 2 BBL carb on my 65 Chevy C10 with a 283 V8. I would like to stay with a 2 BBL carb, but I am open to other options. I have included some PICS of my current carb, which is working well now but the retaining brass ferrell on the throttle shaft is worn and pieces have been cracked off the fitting. Any recommendations or advise is appreciated.
· Registered
the two barrel will be better with mileage but it will handle a 650 holly if you want. i had a 283 vette motor in a 63 Nova that
i switched to a two barrel back in the oil embargo days. you motor would require a manifold swap or expensive adapter.
for a daily driver i would probably stick with the two barrel.
· Super Moderator
1964 C-10-383 stroker-12 bolt posi 1977 shortbox- nasty 454- 12 bolt posi 3:73
Why not have someone rebuild it for you?
· Registered
i have a carb and intake I’ll part with if you are interestedinterested [email protected]
