This may be a dumb question but I'm not seeing where it would go...I just put a brake booster on the truck and I have no idea where the heck to run the booster vaccuum line to...it's 292 stock everything, anyone have and pics or a real good description? Thanks all
Tom
Tom I have never even thought about it. had to go on a search, this is a stock intake although the owner used the same line for both booster and PVC, if no port on intake change intake to a later model unit or spacer under carb with booster port.
Do you have a fitting on the base of the carb or maybe a port on the intake near the carb? The port on the intake may be plugged with a threaded plug that would need to be removed and a hose fitting installed.
That picture is spot on, thank you! And I did find a threaded nut that I need to put a fitting on, thank you!!
