First of all Welcome to the forum, glad to have you here, post some pics when you have a chance....This will require one modification to install the bed, the 60 to 62 frames are wider at the very rear of the frame, the last two bed bolts are further apart, you`ll need to drill out the spot welds at the very rear of the last bed sill under the tailgate and move them in, use a 3/16 drill bit ( sharp ) or new and drill out all the spot welds I think there are 6 or 8 per mount, then measure the 65 frame and move them in that amount, plug weld them into the new location using the drilled holes in the mounts....I have done the same to mine...! sign0016
