I'm thinking about buying a Camaro SS from auction for its drive train but I thought I might try to take it a little farther has anyone here try to take the instrument cluster area and mold it into a first gen c10 . Would the following work take out the motor and trans from the Camaro along with its gas tank center console and its instrument cluster all to put in a 1965 Chevy c10 How hard do you guys think that would be. I think it would make for one sweet ride. Please reply about what you think along with your ideals. Thanks
Certainly doable....and would be time consuming....! Hardest part would be the dash conversion...handle the dash components with caution..is this an LS motor...?
2010 Camaro SS I think that would be an LS4
I had to go look.....curiosity got me...LS3
GM LS3 Engine in a 2008 Chevrolet Corvette
LS3 can also refer to a 402 CID Chevrolet Big-Block engine of the 1970s
The LS3 was introduced as the Corvette's new base engine for the 2008 model year. It produces 430 bhp (321 kW; 436 PS) at 5900 rpm and 424 lb·ft (575 N·m) at 4600 rpm without the optional Corvette exhaust and is SAE certified. The block is an updated version of the LS2 casting featuring a larger bore of 4.06 in (103 mm) creating a displacement of 6,162 cc (6.162 L; 376.0 cu in). It also features higher flowing cylinder heads sourced from the L92, a more aggressive camshaft with 0.551-inch (14.0 mm) lift, a 10.7:1 compression ratio, a revised valvetrain with 6 mm (0.24 in) offset intake rocker arms, a high-flow intake manifold and 47 lb/hr fuel injectors from the LS7 engine.
The L76/L92/LS3 cylinder heads use 2.165 in (55.0 mm) intake valves, and 1.59 in (40 mm) exhaust valves. Improved manufacturing efficiency makes these heads cheaper than the outgoing LS6 heads, and severely undercuts aftermarket heads. The large valves, however, limit maximum rpm - 6000 in the L76 (with AFM), and 6600 in the LS3 (with hollow stem valves).
In addition to the above, a dual-mode exhaust package with a bypass on acceleration was available on C6 Corvettes. The dual-mode exhaust uses vacuum-actuated outlet valves, which control engine noise during low-load operation, but open for maximum performance during high-load operation. The system is similar to the C6 Z06, but uses a 2.5 in (64 mm) diameter exhaust compared to the Z06's 3 in (76 mm). Power is boosted to 436 hp (325 kW) and 428 lb·ft (580 N·m) with this option. A similar system was optional on later model 5th generation Chevrolet Camaros and standard on the 2016-2017 Chevrolet SS, but no horsepower or torque increases were advertised on those vehicles.
From April 2008, Australian performance car manufacturer, HSV, adopted the LS3 as its standard V8 throughout the range, replacing the LS2. The LS3 received modifications for its application to HSV E Series models, producing 425 bhp (317 kW). The LS3 engine in the E Series II GTS (released September 2009) was upgraded to produce 436 bhp (325 kW). All HSV MY12.5 excluding the base Maloo and Clubsport variants have been upgraded to produce 436 bhp (325 kW).
From September 2015 Holden introduced the LS3 in all V8 models of the VF II Commodore and WN II Caprice-V, replacing the 6.0L L77.
Applications:
2008–2013 Chevrolet Corvette
2010–2015 Chevrolet Camaro SS (manual only)
