1 - 11 of 11 Posts
Bama are you lowering your truck...if so yes, you`ll also have to buy shorter shocks..depending on how low you go..
The factory front upper shock mounting arrangement is the weak link on these trucks. A cantilevered bolt using only the frame wall thickness. These brackets correct that by supporting the other end of the shock bolt.
Even if you aren't lowering your truck they are a great addition. The shock absorber technology of today loads shock mounts more than old technology shocks.
Hope that helps!
_______
John anim_25
Well said John,cant tell you how many frames we have patched in that area.Especially when using the Monroe Max shocks
Thanks for the replies, started tearing into my front end tonight. Will be looking to add these, I am going to keep it stock but I noticed the top bolts were not super tight on the shocks to begin with. Seems like this would help support the load of the shock for sure.
They are the only place that has them, only others I have seen were custom built.
Discussion Starter · #11 ·
Thanks 406Rich.
I saw that Eckler's also has 'em... how they are listed on their site(12/2015) :
Part #: 61-247546-1
Chevy Truck Shock Supports, Front, Upper, 1963-1972
-W
Thank you Woogeroo, I always am looking for sources for parts!
1 - 11 of 11 Posts
