my son has a 1990 chevy pickup 5.7 TBI how can we go about switching to a carb and doing away with the computer. the truck ran pretty good but has been sitting for a couple of years doesn't want to throttle up very good and has very little power under load. I changed injectors, throttle position sensor and rebuil trottle body, new air sensor along with water temp sensor Seems to be getting fuel
thanks guys
Senior LS Engine Tech
IS the check engine light on?
Whats the fuel pressure at the TBI unit. This is easy to check most auto parts houses have loan a tool pressure gauges.
When was the fuel filter changed last?
Converting to carb is easy but not cheap you need modify a carb intake to work with the centerbolt heads. Then you will need an HEI disbutor as the computer works the one thats on it. And you will need a fuel pump either electric one you have with a extenal regualtor for the carb or a mech. then you would need to remove the pump in tank.
Another thought if you've already reworked the throttle body (and it's been setting for a while).
Like bo said, check the fuel pressure. For this it should be between 13-15 lbs. If it's not it could be the small rubber tube between the fuel pump and the steel supply line inside the tank. I had one I TROUBLE SHOT FOR DAYS. When the tank was above a certain level it ran great. Once it dropped below the level where the rubber tube was it ran terrible. The rubber had developed a pin hole and was losing presure when exposed.
As for changing to a carb. It's not hard, but it takes money to get all the correct parts to make it work.
Good luck with it.
