I'm having trouble removing the key tumbler from the ignition. Any suggestions and what position does the key need to be in. Thanks
A paper clip or a small Allen wrench will fit into the little hole in the tumbler. As cffisher said, put the ignition in the ACC position, push the paper clip in and pull the cylinder out. It make take a little wiggling and fiddling (the lock cylinder, not you), but eventually it will come out.
Good luck!
