Almost done lots of nice parts new front to rear custom alum radiator dual fans Ls application custom built ls2 alum block
Ls2 with ls3 CNC ported heads from Landspeed head ls3 lightweight intake valves stainless ex Tooley camshaft,springs retainers locks Trunion upgrade, arp bolts ,Autocraft oil pan ,oil cooler ls7 lifters zero decked block arp main studs arp head bolts scoggin dickey oil pump coated ls7 clutch Gm flywheel Gm t56 with stage 2 upgrades short throw shifter billet lokar shifter high hump tunnel 3.5 083 wal driveshaft 1350 joint Yukon dura grip 4:11 gear moser axles moser 12 bolt Hd rear cover no limit fuel tank with intake pump vintage air front runner set up vintage heat n air restomode billet dash vents lokar billet clutch pedals wildwood master cyclinders cluck and brake CPP big brake kit with red powder coated calipers quick ratio steering box AGR power steering cooler, big splined sway bar rear ,ride tech front big sway bar ,alum tie rod adjusters ,welded smoothed frame rails and boxed ride tech coilovers all 4 corners firewall smoothed Dse wiper motor new radio with upgrades for iPhone hookup looks old school but upgraded to fm and Bluetooth fesler billet Taillights porter built rear arms and all custom rear suspension all new glass all stainless polished 1 pc side glass stainless headers coated black porter built hood hinges 20 x10 rear 20x9 fronts Toyo st II tires smoothed factory style inner fender smoothed core support battery relocated to rear new front rear bumpers wiring harness engine harness drive by wire pedal and computer with base tune Snowden bench seat vintage air controls Cory jones A/c panel I did it column and on and on all brand new parts like you c in picture u finish assembly I have the front cap just not installed yet tons of pics from start to now 4 yr project as time permits I work on it or save someone a lot of time will be a nice truck finished its all new never fired or driven yet it's all slick under and ever panel inside and out lots of time n money invested pics don't describe how nice this is need to see in person may take heavy equipment on trade I'm sure I left something out ask if you have any questions 65k OBO
sweet looking truck....! Nice work. beer
