62 K20 wiring vendors?!!!!
284 Views 10 Replies 2 Participants Last post by  rbrduck71
I have search the internet, with no luck, I believe what I need is called starter jumper pigtail/harness
It's above starter and engine on the firewall, it has the 12V accessory wire and two smaller wires in it, any help would be amazing
THANK YOU
BUCK
1 - 11 of 11 Posts
THANK YOU
BUCK
All three wires bolt to starter solenoid
Do you have a picture of what your looking for? What engine are you talking about? Stock or replacement?
Schematic Font Rectangle Parallel Engineering
Product Rectangle Font Parallel Schematic
Are you sure it's not an amp booster relay? Like this...
See less See more
2
Top right of first diagram is what I'm looking for
But it doesn't show the 12 volt accessory wire going to BATT terminal of solenoid
I would like to see diagram at the firewall plug into the dash for our pickup
Did someone remove one of my comments?
Looks like it says Enginge Harness Connector...
I think this is similar to what you're looking for? Call them and ask if they have what you need. All the others I've seen m, seem to be part of a wiring harness..
Check put this post from another forum..it may help you..
I order that harness, it looked close, it seems that it's for gauges
THANK YOU ALL for the responses
Dave S that link to other post gives me what I need, THANK YOU
  • Like
Reactions: 1
1 - 11 of 11 Posts
