1 - 8 of 8 Posts
If you can find a chevy van, up to `86 are ideal, the key is still on the dash for the vans, second choice is any chevy truck to `86, it will have the key on the column, then you will have to decide on whether to use the column or dash key switch, caution when wiring, do not try to hook up the hazard switch as the wiring is totally differant from your `61 agaisnt the later years, you`ll have to slightly modify the parking brake and dash mount but its easy, you`ll need the itermediate shaft from any early to late seventies truck to run from the column to the rag joint. Oh and welcome to the forum...enjoy your stay..
1 - 8 of 8 Posts
