Hello there, I'm trying to understand what makes a 4L60 (92 yr) work its lockup torque converter from a 1992 year Truck in the way it should. As for what I understand the trans is not controlled by a computer. I know there is a 4L60E trans that is controlled by a computer but not a 4L60.
Here is why I'm asking the above question in the way I am asking it. I have a 68 C10 SBC that has a 92 4L60 (casting# 8676358, ID/Suffix Code 2FTM098H, MD8) all ready in it when it was bought in running condition. It has the TV cable hooked up to a Holley 600 vac sec with the Geometry Corrector bracket along with the correct Throttle Cable bracket modified for my stock throttle rod mechanism, I have adjusted the TV cable as required and it does Now go through all the gears much better then before.
I haven't opened up the pan to see whats inside it for any modifications if it has any so at this point I have no idea if it has any up grades or any aftermarket items to it. I also should say that the trans has NO wires going into or out of it from the drivers side behind the out going shift linkage selector lever/rod.
How can I make the trans hookup in its lockup system in a simple way (maybe Factory) without a mass of parts or aftermarket parts. All help or links would be much appreciated, thanks, Marvin
4L60 is shift controlled by tv cable and govenor.Lockup is controlled electrically.You could simply wire in a toggle switch or you could use a vacuum switch to to energize the converter solenoid.The solenoid mounts next to where the filter goes in.Some solenoids were 1 wire and some 2.Just wire as needed to energize and youll have lockup.I have mine wired with both a toggle switch and a vacuum switch.In town I turn it off,out on the highway I turn it on and let the vacuum switch control it depending on engine load.I thin most people just put it on a toggle switch.Also SK Transco makes a kit that will do it hydraulically,but I dont think it will work with a 92 valvebody.I used this on a Toyota FJ V-8 conversion,92 4L60 and 90 valvebody from a suburban.It worked really well
Thanks Blue Goose, I'll have to do some research now on the SK Transco kit and the valve body miss matching 92 to 90.
