Anybody steer me in the right direction to find a pair of these channels ? They are the steel channels that go all around the front door vent glasses and have the pivot shaft out the bottom. Ours rusted away bad and won't hold the glass. Either new or a set of good used ones would help us .
If I'm not mistaken those will interchange up thru 87.The difference being earlier model had 3 screws holding them to the outer edge of door,1 on top and 2 on forward edge.The later models used 2 screws,1 on top and 1 on forward edge.The actual glass with the frame on it I think will swap over to the older channels.You will just need to aquire the rivets and setting tool from someone like LMC etc
