Hello,
I have owned my 72 K-10 for approx. 30 years and actually used it for my primary work vehicle for 16 years straight..... and without adequate brakes. I have spent approx. $15,000 over the years trying to fix my brake problem. I just spent $2,600. last week totally reworking the brake system again with all new parts front & back....with the exception of the original steel lines which had good flow. These were top notch mechanics that studied this truck for two weeks and they thought they could fix it and still no brakes.
Every mechanic including my self says the same thing about the hard pedal and lack of stopping power......its a bad m.cylinder/booster of which I have replaced several times over the years including this time and still.....no brakes.
The symptoms are always the same.....a hard pedal, as if I didn't have vacuum assist or like squeezing the brake fluid through some kind of blockage which is reminiscent of no vacuum, but I have great vacuum. The vacuum booster was changed out twice this time with new replacement booster and once with a working booster from another truck of the same model. Also the proportioning valve was changed out several times and still no difference.
I have a shop manual and know the procedure to bleed the brakes on this model using the tool to hold in the proportioning valve pin etc. etc.
I am beginning to think that this truck is just not ever going to have good brakes..............any advice would be greatly appreciated!!!
Wow that is strange.We had half dozen of that generation of trucks although all were manual brakes and they stopped just fine.Even the earlier models that were drum\drum did fine.I'm assuming yours is disc\drum d52 in front and 11x2 out back.Are you sure vacumn line to booster is not collapsed.Just sounds like something with power assist.I have seen a big difference in the brake lining material but mostly on later models that went semi metallic or ceramic.I do alot of brake work and see sometimes the friction compound just doesn't stop well so I go to a different brand.My best luck was with Bendix.
Thank you for your reply Blue Goose.......There was some speculation that this was originally a manual brake system, but there is no way to know for sure that I know of.
The old brake system(front D52/rear 11"x 2")was what was on it and replaced numerous times before this last replacement using upgraded Delco and CCP mstr.cylinder / booster.
After this latest upgrade it does stop much better, but still not like any power assisted brake system that I have used before.
Everything has been replaced this last time, checked and double checked......with the exception of the steel lines that run from the master cylinder to each flex line. They said that these had good fluid flow.
In the past it has been suggested that I use different brake pads for better stopping power and there was no noticeable difference to me.
I have 18 inches of vacuum currently and it said that this is a minimum and my mechanic said that he wanted to try one more thing and that being installing a vacuum pump on my truck to see it that changes anything and if needed then purchase and install my own.
After this last upgrade it does stop better, but still not like any power assisted brake system that I ever experienced.
Ir it has been upgraded from manual,I think the booster pushrod at the pedal would have to be located closer to the pedal pivot which means there would be an extra hole.I assume the 18 inches of vacuum was checked at the booster.18 should be plenty at idle.
No sir....I find no extra holes in the pedal and yes the vacuum was checked at the carburetor, manifold, and the booster and was always good??
Yours is an interesting dilemma. Have you tried disconnecting the booster vacuum hose, depleting the vacuum storage (15 to 20 hard pumps of the brake pedal) and then seeing if the braking is any better/worse? If there is no change with no vacuum, then you have isolated your problem. If there is a change, then you know that vacuum is not your problem and that it lies elsewhere.
Also was the vacuum checked at the brake booster for sure? Perhaps the vacuum line is collapsed internally? As well, even if you tested the vacuum at the booster you are checking the vacuum in a static condition NOT in the dynamic way the booster will work. The vacuum gauge has a very small volume so a pinhole passage in a collapsed hose will allow enough vacuum to trigger the gauge but will not allow enough volume to power the booster.
Then there is also the possibility of a bad vacuum check valve that was transferred to each successive replacement booster? The best way would be to install a T-fitting and the vacuum gauge AFTER the check valve. But with many heads involved and many new parts thrown at it, I would be surprised if it is this easy.
This may sound quite stupid, yet this is a condition I have personally seen on a few Fords and one GMC:
With the hood open, have someone press down on the brake pedal and view the master cylinder and booster where it is attached to the firewall and note if the firewall flexes or cracks.
This was a common issue on many Fords and in only one instance have I seen it on a GM product.
Other than that, I am unable to think of anything.
